nintendo vs super mario bros
jumbo_000
Permanently Banned
Ypsilanti, Michigan
I have a vs super mario bros and the screen shakes i put the chips and another board and even try another monitor do I have a bad rom set or dose power supply need to be turn up other games play and do no have this help
Hi there. You would probably get more responses to this if it were posted in the repair section. Also, I think your note would benefit from some punctuation. As it stands, it is difficult to read.
Does SMB come up and play with a shaky screen? Or does it not come up at all and you only get shaky garbage graphics on the screen?
I would assume a bad rom set since you tried another monitor and pcb. It could be a fluke thing where you had a loose connection after you switched something out or whatever, and I've never seen a rom set do that, but if you tried it in another board and it still does it, while other games work fine it's the only common denominator.
Game shakes? Could it be the flyback on the monitor?
What do you mean exactly by "game shakes".
smb
the games shakes like it may need a cap kit but it dose not I have a vs baseball pcb when I put that in its cool I even put the smb rom set in the baseball pcb still shakes
