ThunderBunny
Been messing with this for quite a while now. I've got a Nintendo Vs cab with the MultiVS kit installed. I've been trying to get a NES Zapper to work with it to no avail. I can get the trigger to flash the screen but that's about it. A little rundown to what I've done so far. I don't have the gun harness, so at the moment I have it rigged.
I've taken apart the Zapper and took out the transistor and bridged the B and C. I've cut the caps off the board that needed to be cut out per the manual.
Gun wiring:
Purple wire(trigger) to position 1(brown wire) on harness
Blue(hit) to position to position 2(red)
Brown(ground) to ground
White(+5v) to +5v
And alarm is disabled.
I've read they're very sensitive to monitor adjustment and I've changed it every which way, never a hit on screen. Am I completely off here? I want to play some Duck Hunt and Hogans Alley!
Gun wiring:
White(+5v) to +5v
