Nintendo Vs Audio Quiet
Seifer13
Ames, Iowa
I have a Vs Slalom the has bad Audio. When it is turned all the way up you can hardly hear it. I switched out the audio board with a spare lying around but it sounds exactly the same. Because of this it makes me think its not a problem with the audio board. Is the only way to adjust the audio on the monitor?
Did you check the connections on the speaker itself? I had a similar issue in a red tent where the right channel connector was just hanging on by a thread.
