Nintendo VS and Pc10 gun
ATM04
Arlington, Texas
Can these guns be interchanged without changing anything to the original harness? The reason I ask, I picked up a pc a few months ago and an untested gun. Now I picked up a pretty clean vs cabinet with the same orange gun. Neither are working and have the same connectors. Thought I read somewhere one has 4 wires, one has 6?
Can anyone confirm that before I try to make an incompatible gun work on a pc/vs?
Are there schematics out there anyone can share?
thanks,
Md
guns are almost the same
the vs uses 3 grounds, but if you are willing to cut/modify connectors then you could use either gun in either setup
also when looking at the wiring colors on the schematics, make sure you are looking at a schematic for the cabinets harness. the schematic and wiring colors mentioned in the gun kit install, is telling you the wire colors they used for the kit, not the actual colors of your physical harness. you actually have to have the pinouts of both to know what wires you need to hook up. if my giant run on sentence makes any sense
