YieArKade
The 1 amp fuse from the power supply to the iso transformer keeps blowing out.
Could this be a bad iso, or bad power supply? Everything comes on (speakers, pcb, led-buttons, marquee) when I power up the cab. No neck-glow on the monitor.
The iso is 120v with 4 connections: 120v primary, 60hz, 120v secondary, and 1 amp. How can I test the iso or the voltage from the power supply? I haven't done this before.
EDIT: It was the chassis that was causing the problem. It's up and running now!
