Hello Everyone -
I'm listing for sale a Nintendo Super Punch-Out!! complete joystick assembly. It is not fully original, but is mostly original. It is essentially a regular Punch-Out!! assembly body (four-way) with an original Super Punch-Out A5 knob/shaft + pull switch button (bronze copper saucer thing). In order to add the required "ducking pull" microswitch (pulling UPWARDS on the knob/shaft moves the pull switch button activates it), I used a metal bracket from Mike's upgrade kit and a new microswitch for the 5th button on the joystick. So it's not a reproduction joystick, it is an original joystick with a reproduction "ducking pull" button added. It feels like an original Nintendo joystick fully, because it is one. I fully rebuilt this joystick as well (disassembled it, cleaned it carefully, reassembled it to factory specs).
The way the Mike's bracket is designed is that it fits a standard PO joystick, and as a result it utilized the mounting holes (where the joystick is mounted to the panel) to secure the ducking pull bracket. This means that you may need to adjust the positioning when mounting to your panel to ensure that it will operate correctly. For now, I've secured the bracket with two zip ties - these should be removed when mounting to your control panel. Feel free to message me with any questions.
I'm thinking $90 shipped to the US if paying with Zelle (highly preferred) or $110 shipped if paying with Paypal. Contact me separately if you are out of the US to discuss shipping options.
