Nintendo sanyo monitor problem
Bodie
Wichita Falls, Texas
I just recaped and replaced the burned out flyback in my Nintendo Sanyo monitor from a Vs. SuperMario. I am having a brightness issue. The screen will not adjust down in brightness with either knob, and the tube shuts off.
Does anyone have any suggestions.
Thanks, in advance.
Did you check/set your B+ voltage? If it's too high, this can happen. The test point on the chassis is labelled BJ. You're looking for 108v
-Ian
