This is a nearly complete Nintendo red tent that is ready for you to take across the finish line. I've had this cabinet for years, which started as a MAME cabinet while I spent several years tracking down all the parts I needed to convert it back to stock. I've finally got all the parts installed, there is just a bit more work to complete before it's 100% ready.
The body was fairly scratched and dinged up when I got it. I primed and re-painted using Rustoleum red and black. Legs are unaltered chrome, which show a bit of wear. Cash boxes are present.
It has the original smoke/tinted plexiglass and clear glass pains for the monitor areas.
I had a couple of new clear plexiglass panels created for the instruction card areas.
Buttons, joysticks, and control panels are all stock.
Wiring harnesses are original and have not been hacked up.
PCB was sourced from ebay and is working. Only one side is populated (Super Mario Bros. VS).
Has original transformer and power supply. I also have a spare power supply.
One side is working completely; Super Mario Bros and looks, plays, and sounds great (including 2 players). This Sanyo 18-Z2AB shows a minor amount of burn in from a previous life of running Castlevania, but it's not visible when the screen is on.
The second side has a Sharp XM-1801N screen, which is currently not working. When switched on you can see a red dot in the middle of the screen, but nothing else. I have a cap kit but I never got around to installing it. I'm not sure if the cap kit will fix it, or more adjustments will be needed. The second side speaker will also need a new molex connector in order to connect to the harness.
My interests have shifted to pinball, so my interest in re-capping the second monitor has faded. I'm ready to pass this on to another enthusiast.
Original parts:
$1700. $1200
Status update: Sold/Traded
Original parts:
- Joysticks / buttons / control panels
- Tinted plexiglass and glass panes for screens
- Cash boxes
- Wiring harnesses
- PCB
- Power Supply
- Transformer
- CRT: Sanyo 18-Z2AB
- CRT: Sharp XM-1801N (not working)
- Speakers
- Coin mechs
- Re-painted with Rustoleum
- Plexiglass instruction card covers
- Extra long power cord
- 4 new keys
- Power Supply
- Clear plexiglass for monitors (if you don't like the o.g. tintned ones)
- Sharp XM-1801N cap kit from arcadepartsandrepair.com
- CRT Repair: Sharp XM-1801N
- Molex connector for 1 speaker
- Source ROMs and PPU for side 2
