Thought I'd share some boredom...
Well, had some work to do on an Arm Wrestling conversion from a Playchoice 10.
I ended up using a PunchOut CP, since I could not find an AW one.
Filled the holes with plugs, sanded down the old CPO and drilled new. Now to see if the measurements were correct!
The latch holders bolts wouldn't come off....cut them out and put in studs. Turned out ok...
Still have to fill the holes around the action button (where the PO joy was) and apply the CPO.
Pics to come later of completed panel.
