mhaaland
Here is the list of which Nintendo power supply goes to each game:
http://home.comcast.net/~mtpacifico/_kenskorner/files/Nintendo Arcade Game Power Supplies.pdf
Dang Ken, did you take that list down?
Thank you!
i have the best cap kits on my site for the nintendo power supplies that all the caps are nichicon 105c perfect fit with case size and lead spacing and low esr 5000-10000hour caps.
How do infinite out which power supply I have on my DK?
99% its a pp7b show us a picture
yup matt is correct (as always)if you have a blue donkey kong original it should be pp-7b and the 1% (red DK) had the pp-7a. post a picture to be sure and usually there is a sticker on the side of them too.
I think the sticker is where the 100v ac comes in which should be facing the coin door. Pics will help us. It could also be a new switcher ps put in there awhile ago which don't always last.
PS: this guy has good kits on his site so if you need one grab it and reflow solder while your at
When I just turn the DK I have no issues, but when all my games are running it glitches. One glitch is that the game screen blinks and distorts between level changes. And then if left on for hours the game play screen will distort as if the v/h hold is going out.
This is why I was looking to recap the PS
Yeah that's a PP7b and recapping it could never hurt. Are you sure your wall is equipped to run all those games because it sounds like voltage drop. Try capping it and see where you get. The hold could just be the monitor needing caps too which isn't too bad on a 20ez they're labeled well. Security has all the cap kits on his site. Be sure to get a filter cap for the sanyo too its a 470uf 160v which may be rated higher volts on his site but will work fine. I cap all my sanyo's whether they work or not and reflow any cloudy solder on both monitor and ps's.
How is filter cap different than a regular cap? And thanks.
Hi, sorry to blow the dust of this old thread, but I have the same question and it wasn't really anwered in this thread - or anywhere else for that matter. I have a PP-7B with 2200uf caps in C15 and C16. The print on the board says 3D-0097 which is the same as all the images I have found of PP-7Bs on the net. The original boardset is a DK TKG3.whats the deal with the c15/c16 caps on the pp7b, both the schematics i have list them as 2200 not 3300, i have a two units one uses 2200 the other 3300. id be inclined to replace like for like but i have a bunch of spare 3300 caps. are they interchangable or is there slightly different pp7bs out there?
cheers
