Nintendo Monitor connections help
MKplayer1start
Toronto, Ontario, Canada
I have a Nintendo cab that is gutted except the monitor and iso transformer. I will be restoring this cab but the inside of the cab will be wired up jamma at least for now.
I need a little help with the monitor chassis connections since I am new to nintendo cabs
here's a pic of what I believe to be the RGB input:
Can anybody tell me what each pin is from Left to Right (Red, Green, Blue, Ground, Sync) ?
and since I'm wiring this up jamma does the connection "Non Invert out" get connected to the monitor chassis?:
at this location on the chassis?:
I found this:
index.php
does that look right? says to use invert out for non nintendo games and non invert out for Nintendo games. I thought it was the opposite?
it's the other way around. I know it sounds strange. lol (the terminology, not the connections in the picture)
for whatever reason both monitors in my PC-10 have these inverter boards, even though I don't think it needs them. I have 2ZAW's in it.
Thanks for the clarification. So Invert Out (Non Nintendo) would be connected to the chassis for a jamma hookup.
another question about the input. it has 2 grounds and a jamma harness has 1 video ground. am I good to just hookup the 1 video ground?
I would think you can get away with hooking to just one. ground is ground, they all go to the same place right?
you only need one ground not two and it will require +12vdc to power the inverter board as well not 16vdc as listed.
