Nintendo molex connectors?
dethfactor
Donor 3 years: 2011, 2013, 2021
Portage, Indiana
So I'm restoring a Punch-Out and I have most of the wiring in the cab in but the switching supply on the cage I have isnt the right one and doesn't have the right connectors. So I want to use a regular switcher and not hack the harness but need to pick up the 12pin female, 9 pin female and 3 pin female for the power. I also need to build out the harnesses to the speakers so I need 2 female and 1 male 2 pin connector. Any ideas where to get them?
Dokert, do you possibly know this?
The molex looking connectors Nintendo used aren't available. The speaker connectors you could use any 2 pin connector if you changed all of them to the same male/female. They wouldn't be original, but it would work.
The only way I can think to get the others is to find another power supply dead or alive and remove the connectors from it and build adapters. The connectors are actually pigtales that have another plug onto the power supply board. I have a dead power supply but the previous owner robbed the parts you'd need. - Barry
Well I have two of the three I need. I either need a PP-1000A switchers or one of the 12 pin connectors out of one. I have a switcher for VS Pac conversion with the 3/9 pin connectors if someone wants to trade??
