FS Parts: Nintendo isolation tranformers
drewscruis
Eden, New York
I have 2 from cocktails and 1 from an upright (has new on/off switch). All worked when pulled. $65 shipped for each one.
I use one of these for my test bench and it can test all monitors. The voltage works fine for all brands. The plugins and on/off switch are nice features to have built-in.
You test regular monitors with the 100v output? Or do you reconfigure the voltage wire?
Can someone explain this for me as well? I know you could wire it up on a toggle to do say 100v and 115v - But how would you actually wire it up? How do you get the higher voltage out of the iso? Thanks
I think what he's saying is most monitors will run on the 100v just fine, it's the other way around that matters. I think most have an operating range of 100-130v or something like that. Each monitor's manual should have the range.
Some people say it's not good, but I've run a monitor that way and it seems fine. To be fair, I also plugged the same monitor INTO THE WALL as a newbie not knowing about isolation and it didn't care... (This wasn't a modern monitor with iso built in, was an 19" Electrohome, what a beast)
send the 115/120V in via the 100V input tap. The output voltage will be 115/120V isolated as the windings are then 1:1.
Send the power in the 115/120V tap and the output will be 100V.
