DreamTR
Ok so on these harnesses, if you "don't" have the Gun Power Harness, the gun will fire but nothing will appear on screen, correct? I just got a power harness attachment and for some reason the 4 pin connector to the wiring for the coin door is not the same as the harness. Just trying to check and see if that is the case and if so if I have to cut these wires....
