Nintendo dk series Instruction Sticker holder?
No problem at all.
To remove the bezel you need to loosen the bezel retainer rod in the back of the cab (You'll see it almost directly underneith the serial# plate).
Then pull the tbe back . Then just take a putty knife or even a steak knife to lift the bezel out of the groove it sits in on the instruction panel and then slide it out forward.
Good luck.
ERIC
