Dumbass Question of the Week: Can anyone tell me what router bit I use to accomplish the cut necessary on a piece of plywood to make the bottom of a Nintendo back door?
I have no problem cutting the door to size... I just don't know what router bit to use to make the bottom "notch" cut...
i've always just used a table saw to cut notches with. Adjust the height of the blade to the correct height, and run it across the saw. Stand the plywood up and then run it through again (adjusting the height and guide as needed).
Just get a rabbit or straight cut bit with a bearing for the router.
They have different size bearings to control the width of the cut.
You just need to set the depth on the router.
No guide needed. Easiest way to do it. It is more of a pain to run a big piece of plywood on the table saw.
This is what you need http://www.toolstoday.com/p-5100-mu...35wmTvksp0QElfcgA8e7ERoC2rLw_wcB&refresh=true
I have one with multiple bearings for different widths.
