Nintedo Cab Bolts
CMGTGuy
Mooresville, North Carolina
Which bolts are used in a Mario Brothers Conversion to hold the monitor up? I'm working on coverting my DK 3, but it currently only has the two bolts at the top of the cab. Trying to figure out if I need to add three more bolts.
Yeah, you need 3 more on each side. Mario is a horizontal game where DK3 is vertical. You need the side rails that the monitor will sit on. PM DJ DNS he has a ton of em' he's selling...he might have the bolts too.
Good luck,
ERIC
I've got the cab, I need a template for the new holes I'll have to drill and then I'll need the bolts. Anyone have a template or the bolts?
Anyone with a conversion cab, a popeye or a Mario should be able to hook you up with the measurments. I have a Popeye and I'll see if I can pull it out and measure the bolt position for you this afternoon.
ERIC
