I am, but it beeps every time it goes into OC. I don't want to listen to that.Use the current limiting feature of the PS.
That will auto adjust the voltage to ensure you never go over the current you specify.
You are probably right. I'll play around with the internal parts and get a good finish on those before I try the coin return buttons.years ago i bought out a small pcb assembly company and i got a few gallons of nickel plating solution. i have been wanting to do something with them for a long time. i am no expert in this area but i belive the copper wire will mess with your finish. instead you would be making cupronickel which is an alloy of copper and nickel (both solutions are green) also if you intend to plate nickel you would likely have better results plating copper first then nickel .
edit: well copper solution is blue but it would hide easy in a green solution
OK, I did some more reading. Plating with copper first does help with corrosion. The copper wire does not contaminate the nickel solution because it's on the cathode side while plating. I made the solution with two nickel plates. There was no copper involved. I just plated the copper wire holding the part in the end. If the copper contaminated the solution then whatever metal you try to plate will do the same.years ago i bought out a small pcb assembly company and i got a few gallons of nickel plating solution. i have been wanting to do something with them for a long time. i am no expert in this area but i belive the copper wire will mess with your finish. instead you would be making cupronickel which is an alloy of copper and nickel (both solutions are green) also if you intend to plate nickel you would likely have better results plating copper first then nickel .
