shopboyroy
NIB 25 inch MAKVISION CGA MONITOR
I purchased a few of these a while back and am down to two. One is spoken for (my Pac man machine), the other I'll take $325 for it shipped (to lower 48). This is a new in the box, never out of the box, box never opened, brand new unit.
CRT Size
25" (24.8" viable area)
Dot Pitch
0.79mm
Video Input
Analog 0.7VPP (75Ω)/TTL 2.5-5.0VPP (2KΩ)
H-Frequency
15KHz
V-Frequency
47-70Hz
Bandwidth
65MHz
Resolution
640 x 200 max
Power Supply
100-240VAC 50/60Hz
Power Consumption
120W
Weight
75 lbs
CRT Size
Dot Pitch
0.79mm
Video Input
H-Frequency
15KHz
V-Frequency
47-70Hz
Bandwidth
65MHz
Resolution
640 x 200 max
Power Supply
100-240VAC 50/60Hz
Power Consumption
120W
Weight
75 lbs
