:-/ NFS Underground Immersion USB board repair. 1.0Ωj 2w resistor
Ok so,.. Picked up a NFS underground. New monitor, The 24 v power supply was dead, and I bought a new power pro 24 v power supply. I should have looked over the board a little bit better because almost right after I powered it up, pop, little flash and then I shut down the power. I looked over it with a flashlight but must have missed a little discoloration on the 1.0Ωj 2w resistor. At least I am pretty sure it is a resistor.
So my question is this, Iiii never changed out a resistor I am not even sure where to look, Is this a particular kind of resistor that needs only this band or symbol line up 1.0Ωj 2w .. I found one that was close a k not a J.. But these are the things I felt I better ask people who did this before. Luckily the board under the resistor does not look burned at all or damaged.
Of all the projects I did, this one is the one I am learning the most off of lol. But that is why I started doing these. To learn and grow. Just hate being so green at times. Well that and not wanting to do even more damage to the board etc.
Pictures,.. board when brought home, can see a little discoloration.
The other 2 of the resistor.
