tinsley
I need help. I have a NFL Blitz that came with Blitz chips and HD, Blitz 99 chips and HD and I ordered a 2000 upgrade chips with HD. I turn it on, it runs its test, and reboots. Every time, no matter which set I have in. No way do I have 3 bad HDs. What the hell could be the issue? Is it detecting something after those tests and just shutting down? I am so lost. I am trying to run this on a STD def monitor and 8-way joysticks inside my NBA Jam cab. I know the PCB has dips for those settings, which I have checked and checked and I think I have set correctly. This is also the 2nd PCB i have been thru, thinking the 1st PCB was bad. Again, no way I got a 2nd PCB with the exact same issue.... So, what else could it be?
