NFL Blitz Midway controller probs....
AmishHitman
Memphis, Indiana
I got a 2000 Blitz/NBA showtime (as many of you already know...HA) My player 3 is not working correctly, when I do the switch test the up is down the left is right the down is shoot etc. None of the buttons are indicating start or coin up on the player 3 and none are correct. My question is that it appears to have the factory harness. The wires won't reach to simply reconnect them to right spot, is there a DIP switch for this or is it just as simple as rewiring it.
Had this problem on my Blitz. I'm going to assume your using 8 way and not optical joysticks here. Follow the wiring from the joys back towards the harness. Should be a spot with plastic connectors. Make sure the it's connected correctly and not one pin off. You'll also want to make sure that the wires are in.
Yeah it's an 8 way. I'll give it a shot. Do you know if it's hard to convert over to the eliptical ones? I have a spare blitz
my Sportstation uses the I-40. I imagine Showtime does too. to my understanding the only games of this type that don't use the I-40, but have 49-ways, are the Gauntlet games.
if you're already running 8-ways with it, then your connectors have already been chopped off the wiring harnesses. you'd either need to crimp new connectors on the existing wiring or find new harnesses for the I-40 -> 49-way joysticks.
