ModCity Active member VAPS Joined Aug 11, 2010 Messages 362 Reaction score 30 Location Freeman, South Dakota Sep 6, 2010 #1 Anyone have them? Had a chance to pick one up, but couldn't figure out if I could fit it through the front door. My doorway, sans door, is 36" wide.
modessitt Volunteer: Encyclopedia Submission Moderator VAPS Joined Mar 22, 2007 Messages 33,414 Reaction score 325 Location Austin, Texas Sep 6, 2010 #2 Well, it depends on which cab it's in: Dedicated upright w/ 25" monitor H: 73.5" W: 37" D: 43" Lbs: 500 You can remove the control panel to get it through the door. Showcase cab with 33" monitor H: 73.5" W: 43" D: 68" Lbs: 800 You can remove the pedestal from the monitor and move both pieces in sideways. Conversion Cab Have to figure out what cab it's in first....
OP OP ModCity Active member VAPS Joined Aug 11, 2010 Messages 362 Reaction score 30 Location Freeman, South Dakota Sep 6, 2010 #3 It was not a showcase cab, for sure. If taking off the control panel is all it would take to get it in here, that would have been sweet. Likely an opportunity that got past me. Information is power, right? Thanks for the answer, man. Last edited: Sep 6, 2010
