I had a NFL Blitz/NBA showtime NBA on NBC board has seem to die i was wondering does anyone know where i can get another complete PCB board setup i cant seem to find anything anywhere??
Place a wanted post here or keep checking ebay. Not gonna be cheap though. They fail fairly often and usually can't be repaired due to the processors being proprietary.
First of all these boards can be tough to acquire.
Secondly, you need to watch your boards LED's because the flash code will actually tell you where to look for the problem.
You don;t mention if you've checked the +5 rail
and video cards are very common to crap out on these especially if the fan is either missing or dead.
Yea i was able to find one on ebay it wasnt cheap at all the one im getting is 100% working order i just hope it last me a while i have 3 fans that i will be hooking up rather be safe and sorry again the one i ruin before was 100% my fault i screwed up on the install and smoked the whole board and even killed the hard drive. Hopefully have better luck this time around.
