NFL Blitz 99 Startup issue.
bigjeeps1
Springfield, Missouri
I have a NFL Blitz 99/showtime 4player that is acting up. I turned it on yesterday to play a game with the father and it was in like 2 player screwed up mode.
It would only take credit on the number 1&2 player and the joysticks were stuck in the down mode according to the action on the screen. I checked the dip switch setting and it is on 4player mode. It does the same thing in showtime. Help would be greatly appreciated.
Check your voltage to the board first. Adjust if needed. Go into the service menu and Run a check on the hard drive. They go bad frequently.
One more thing check the I/o board for a good connection. I had an issue with a carnevil and the gun I/o board. Needed a good cleaning on the contacts and put back on and works great now
Well voltages are good I found the CPU reset button, hit it and that got it back to where the 2controllers are working right now i cant play 4player. I think i might need a cpu.
