NFL Blitz 99 joystick problem
Field305
Miami, Florida
Hi all, Just picked up a 4 player NFL Blitz with only 1 problem.
For some reason the 3rd player joystick is registering "up" when I press down on the joystick. Everything else works fine, but I cant move the player down. Any help would be greatly appreciated.
So basically every joystick command works fine, except down which makes the player move up.
another fellow Floridan had the same problem with a blitz (Rome) and he cured it with a new I40 board, you can test the joystick itself by plugging it into a different player and checked the actual stick works okay, but the problem sounds just like the one he had, so check that if possible?
