MmSadda
Okay, I have two NFL Blitz 99 boards now. The first one worked fine for several months before starting to freeze during the attract mode. I bought a second one, and hooked it up to the hard drive from the first one, and it seemed fine the first time I powered it on. Now, after leaving it on for longer and letting it run through the attract mode, it freezes or experiences a text glitch, similar to what the other one did.
Could my hard drive be the problem here? Am I just that unlucky that I've got two bad boards? Or should I look at other things such as voltage? (several other games have run in this cabinet for hours with no trouble whatsoever. I find an issue with the power supply rather hard to picture, but am open to ideas)
For what it's worth, I thought the first one had died due to the board being flexed. However, this second one has been babied in the time it's been in my possession - I kept it sitting flat, stored away safely, until I was able to mount the PCB on plywood.
I'm open to thoughts or suggestions - please let me know if you have any.
-Collin
-Collin
