modessitt
Background - I rebuilt this thing a month or two ago and it was working fine. Installed new flyback, HOT, VR, caps, critical safety cap, and cleaned up a bunch of cold solder around the horizontal width coil. Game (not mine) has been in a commercial location, plugged into a surge protector, but I have no idea if it is turned off at night. I'm sure it runs at least 12 hours every day.
I got a call that the game wasn't working. Had them do some stuff over the phone and determined that it was playing blind, so I went and picked it up.
Here's where it gets mysterious.
I have power to the monitor. Fuse is good. HOT, VR and safety cap read as good. B+ is reading at +123vdc (which is spot on). But I have no HV at the anode cup and I have no neck glow. I pulled one side of D10, but it still won't work, so it's not in shutdown mode.
I was doing voltage checks via the schematic, and seem to have them where I should. I also checked R213 on the neckboard to see if it was keeping my heater voltage away, but it is fine.
I guess my next step is to check IC2 and C36, but does anybody else have an idea? What are the odds the brand new flyback is dead without blowing?
And no, this is not Shardian's chassis. I opened his up to find that there was no VR installed, and the two he sent along were blown, so I have to get some before I can check it out...
