vicjw66
Hard to tell but it looks missing. I don't suppose you have a meter handy. I get no continuity between the two points. Thanks
It seems as if a diode is in the circuit somewhere?
iirc, there's a small electrolytic cap and a large filter cap on the lamp driver pcb, replacing them should help with the popping in the speakers when the lights come and go.
EDIT: BTW - Like a CAP where you can go up on the voltage side without worry, can you do the same on the WATTAGE side of a resister? For example, could I use a 2.2ohm 2w or 2.2ohm 10w resistor?
i think your supposed to set the accelerator to read 0b when not being pressed. It tells you on the pot calibration page for sure.
