Newbie with a tube and a diagram - need expert help...
I picked up a shell cabinet with a monitor and I thought I was ready to go... And then I realized it was just a tube with no chassis.
From the diagram and model number stickers it looks like it used to have a WG chassis attached to it. I originally thought I should just try to find a replacement, but then those seemed hard to come by. After even more digging, it seems like the WG chassis boards are a bit tempermental.
So, the questions are:
1. Are there "new" chassis boards that can be attached to existing tubes that are more reliable?
2. What model WG would work best with this tube?
Hopefully the attached images help ID my problem and associated solution. If not, let me know what you need. The third images wouldn't upload, but all it showed was the model number of the tube: RCA A63ADT10X05-3
Thanks in advance!
Josh Anderson
Thanks in advance!
Josh Anderson
