newbie question on voltage testing
KazooBR
Donor 3 years: 2023-2025
Kalamazoo, Michigan
Ok, I'm not an expert with a MM and I can't figure out what I'm doing wrong. I'm working on my Gorf restore and trying to verify voltages. I don't get readings that look anything like they are supposed to.
See the attached pic. I'm grounded to the noise filter pin. Some power gets through (I'm sure the on/off and service switch are on). Pin 5 is supposed to be 9v. I've got my MM set to the 20v DC range and it bounces around between 0 and 1 or 2.
What am I doing wrong??
This is from a working game so it should be fine, the only thing I did was replace the power cord and hook up that ground on the noise filter because it was cut off.
Thanks,
Brian
Well, first off you should hook your ground to a DC ground on that board instead of an AC ground when measuring DC voltage, as that will be most reliable. You may not be getting a good ground for the voltage you are trying to read, as it may not have a good connection to the circuit.
Second, you may not be getting a reading because there is something wrong with the voltage line.
Third, low batteries can also cause readings to look funny....
It was the ground I was using. I thought all grounds were created equal!
I used one from the board itself and all was good.
Thanks!!!!
