I am a newbie to the forum and this is my first post.
I have a Williams Flash pinball with a problem. The game appears to start up OK. When you play the first ball and it returns to the out hole, the game does not recognize that the ball is there. It does not eject the ball for next play and does not indicate ball number 2 is in play.
I have checked the hole switch and diode all the way to the connector and it measures correctly with the switch closed (and open). I guess the next step is to check the driver board row and column switch input. Any ideas?
What is odd is that this was working when I played it before I bought the game at the sellers location but has never worked after I got it home.
