newbie - Monitor only showing black and white
ncclone
Iowa
I just got a Target Pro Toss Bags with lawn darts arcade. Worked great when I got it, moved it to my basement and now the screen only is in black and white. Everything else is working fine. We have messed with all the connections and still doesn't show color. Any thoughts on what to try to get color back?
thanks
Jason
I looked at the monitor and it has sticker that says WGEC Tube Type 088X0387-001. Does this help? Sorry this is all new me.
Jason
just post pictures of the chassis. (not the tube)
I ordered the resistors and got them. Moved the cabinet to start replacing and it and the monitor showed color again. Played for a couple minutes and went back to grey. Would this still be the resistor or something else?
Check the resistor you just replaced by using the Ohms setting on your multimeter(if you have one). It should still be 75k.
