WadeLanham
Same as the kortek right? Monitor tube makes green, which is good. The green problem is upstream. That's consistent with the game board signal / bad wire theory.Turned on the 4800 before work. Turned up both the green gain and green cut off, both work fine. It does seem to put a little bit too much green or not enough green just like the other ones. Plus once I get the image centered Horizontally, it starts to bow super bad.
