new power supply for paperboy; prize
jcterzin
Richmond, Indiana
Hello e'rebody!
Its been a while. Anyways, I was hoping that someone would take the time and really help me out. I need to rewire a paperboy with a new switching power supply, since the video board is not getting the proper voltage that it requires. There are like 10 or so wires that go from the AR/III to that board, and I dont know which ones need however much power... If someone could take a picture of them and label which ones require which amount of power, and it works for me, Ill send you a paperboy tshirt I printed up a couple of months ago on the house.
ive been working on this arcade for 6 months to no avail, its really kicking my butt.
You can just connect the power to the upper left connector on the top board, then run a jumper wire from the +5 and GND test points of the upper board to the same points on the bottom board, and it will work. I had a guy have me do that for him, when he didn't care to spend a lot of money on fixing it properly.
Then disconnect the ARIII wiring that is duplicated by the switcher...
