tinsley
I am pulling a monitor from a newer machine (well, newer then PP, this is coming from a cab from late 80's, early 90's) that uses a iso transformer and i want to use it in my Pole Position cab. What would I need to do for it to work? I don't think PP uses and iso transformer, does it? I am confused here. The monitor works fine in its original cab. Moved it to PP, it didn't work. Put it back in original cab (to make sure I didn't 'F it up) and it worked. The PP cab is working as it had a working monitor in it, it just had a lot of screen burn so I am replacing it. What do I need to do to get the new one working? I am not sure of the chassis type, I can take pictures tomorrow. Do I need to add a new iso transformer for the monitor? Is it a sync issue (heard PP uses a different sync then most games) or what? Any help is appreciated...
