new makvision m3129 DF-TS monitor questions
r5g_on_klov
Nevada
supposed tri res auto sync monitor,
tested it, unknown if result is right, this is in f/s section too
basically it works when a 60-1 pcb is in low res mode via dip on the multigame board, and then using the vga connector?
but if i put the 60-1 pcb dip on hi res output, 31khz, and use the vga connector, the monitor ticks in the resolution area, and the image size is not right or stable? im not sure if theres a problem ?
or maybe it just does not like the setup/ hookup?
i thought this monitor was supposed to auto adj. to any setup?
