New Makvision 29" Monitor Questions
cnhartwel
Indiana
So I recently got this monitor and was a little disappointed to see a few issues and I am not sure if they are simple fixes or if I received a bad monitor. There is a blue line that goes vertically down the screen slightly to the left of the center and it seems to move to the right and left when I adjust the horizontal size, position, etc. Not sure if there is a way to get that removed. Also, the center of the screen looks great, the colors are spot on and its sharp but moving to the left and right towards the sides the RGB seem to separate, or not converge anymore and I can see rgb pixels(I know that is not technical but the best way I can describe it).
Let me know if I am not making enough sense. I am new to arcade monitor issues and fixes so any help is certainly appreciated. I had heard good things about this monitor and for the money I was expecting more but I have no problem spending the time and effort tweaking it if its possible. Thanks for any help with this matter. I do appreciate it
I'm going to assume you bought the tri-sync 29" MakVision. I don't think they make a CGA version anymore but correct me if I'm wrong.
I have not run into any blue line issues. If it's brand new and you have solid signal, that should definitely not be happening. As for the pic "curling", have you played with your H-Sync/V-Sync pots? It might be that simple. You will get a bit of curling on the bottom right in CGA/15khz games on this monitor but its pretty minor.
Pic would be great to see the blue line.
