First off, big thanks to Madocowain for donating what was left of a water damaged Edot, and Seawolf for picking it up and delivering it to my house. Also a big thanks to OU FLight for a copy of the factory EDOT plans too. This thing took a WEEK to build. Very complicated, and damn near every part had something you had to add to it with a tablesaw. The only thing not done is the strips on the floor, i have to go grab some 3/8ths ply to finish it.
Cabinet is going to be joined together with 1/8" steel plates, both on the inside. Angled panel at top will hide the plate, and bottom plate will be hid by floor target. i added 2 more leg levelers for stability, and also buscuit joints on the joined seams. The inside 2 levelers will need cut down to not interfere with floor target.
