new comp lcd's are cheap now but which one?
r5g
Nevada
i have seen 18.5" thru 21" on sale various places for 99 to 129
finally cheap enough for the multi game use
some q's
1. which ones are best /easiest to use /install?
2. do they come on without windows software?
3. which size is closest to the original rgb low res 19" the sizes are not the same it looks like the lcd is longer than the old rgb in the horiz direction.? im gussing 21" close?
4.what are some install tricks it look like if you could put some kind of tri angle shaped courner holder over the edges they would install nice in most cabs?
I go for the cheapest 19" LCD. Then I turn the sharpness all the way down to try and blur the edges. I have yet to see any kind of monitor that needs drivers, so all of them will work plug and play. On the cocktail I made, I cut my own wooden frame with braces supporting it from behind. Works really well if the monitors have built in mounting holes on the back
