- Joined
- Aug 3, 2009
- Messages
- 5,152
- Reaction score
- 534
Don't forget to check out my thread on splitting the CPO on a corner cut so that the Capcom logo shows on the top face of the CP.
The HS5 25" cabs can do the same but the monitor is mounted to two pieces of wood (top and bottom) to create the same effect instead of just stuck in one square piece of wood. I'm not sure if the Z-back cabs have the same thing since I don't like them, I've never owned one.
You'll find that some empty cabs that you find may have lost their monitor mounting pieces of wood. This is a problem if you can't find a template to build new ones. I was able to figure it out myself on my HS5 cab that I got empty.
Eh I've got some pretty deep cabs already so this one wouldn't stick out much.Forget the big blues, they are nice in some ways but really are hard to fit. They CP comes out so far that it breaks up your rows. You'd need to stick it next to a super deep cab like a Konami or Sega Fighter.
I like HS1 and HS5 cabs for a nice 2P vs cab...
We do see a bunch of KOAMs in this area cause 3KOAM was just like 10 miles from where I am.
Eh I've got some pretty deep cabs already so this one wouldn't stick out much.If I can't find the big blue cab I'd probably settle for a red Z Back. I know this has been debated over and over here, but for a long time, I thought the red Z back cabinet was the dedicated for Champion Edition. Only later did I learn about the big blue cabinets. I had never even heard of 3KOAM until recently. Interesting to know what other companies besides Dynamo were making cabinets.
Can you find me an affordable SF cab in the Yay Area?
My HS5 actually has metal mounting brackets. There are a set on the top and on the side, then there are two pieces of metal that will bolt to your monitor frame, and then whichever brackets you need to mount to at the time.
The HS5 houses a 25" monitor, and is just a few inches wider than the HS1, which is made for a 19" monitor.
Aside from that, and a drawer inside, they are pretty much the same.
My HS1 and HS5 are even the same depth, height and match side by side, but the HS5 has a "box" built on to the back for the larger monitor neck.
I guess mine has two different monitor mounting brackets as well, but I've seen a few different styles on those.
Thanks Mindl3ss and Prairied1ll0. I just got a Tetris in a Dynamo, but I wasn't sure what model it was. Sounds closer to the HS2 description. It has the pull-out CP with the board attached. The monitor is a 19". I wonder if it can be rotated? I'll have to check it out.
pm me, might have an extra z-back or something...
My HS-5 was just wood in the inside, I had to trim it to cram a 27" VGA monitor in it, but is looks awesome with the naomi!
