New buttons and sticks...help.
joebunn
North Carolina
I've just received my new buttons and joysticks for my NBA Jam TE (first arcade game I've actually owned). Can someone give me a good idea of going about replacing this stuff without getting super confused? Any tips are much appreciated.
do one wire at a time take your time. you could always put a piece of masking tape on down and or left if remembering is an issue :D
re installation is just reverse of removal
I think the first time I did it I used masking tape and a sharpie to label each wire. I was so paranoid about hooking things up wrong. If you have the parts, take the time to replace any bad quick disconnects while you're at it. It'll make your life a lot easier in the future. Just make sure to run test mode when you're done. It's the quickest way to confirm everything is working properly.
