I'm sorry... I'm not trying to be cruel, but you clearly have no idea what you are doing....
Why don't you step back, pull out the Pac schems, and try to understand what the hack is first. Read the ROMs that came on the board and figure out what it's running (my guess is that it is a bootleg MsPac set, but I think we already covered that in another thread).
Yep your right I don't know. That's why I am asking questions. How that could be seen as cruel idk at least you gave some advise. That's progress as far as I am concerned. Anyway I am reading the instructions that I have and to this point I have followed what they say I belive.
Here take a look at some of them...
These images are used for converting a Pacman board to Ms.Pacman using
2532 EPROMs.
MSPAC6E.532 : Ms.Pacman 2532 EPROM image for position 6E.
MSPAC6F.532 : Ms.Pacman 2532 EPROM image for position 6F.
MSPAC6FF.532 : Ms.Pacman 2532 EPROM fast speedup image for position 6F.
MSPAC6FC.532 : Ms.Pacman 2532 EPROM image for position 6F with CHEAT*.
MSPA6FFC.532 : Ms.Pacman 2532 EPROM fast speedup image for 6F with CHEAT*.
MSPAC6H.532 : Ms.Pacman 2532 EPROM image for position 6H.
MSPAC6J.532 : Ms.Pacman 2532 EPROM image for position 6J.
MSPAC6K.532 : Ms.Pacman 2532 EPROM image for position 6K.
MSPAC6L.532 : Ms.Pacman 2532 EPROM image for position 6L.
MSPAC5E.532 : Ms.Pacman 2532 EPROM image for position 5E.
MSPAC5F.532 : Ms.Pacman 2532 EPROM image for position 5F.
I think I have followed the instructions to the tee (so far)? This is where I am to this point. Now....
Here is where it gets confusing at... I will post the whole set of instructions!
Ms.Pacman EPROM conversion image files.
These images are used for combining row 5 and/or row 6 multiple
EPROMs into a single EPROM. Also used for multiple game conversions.
4PACROW6.010 : Contains 4 versions of Pacman/Ms.Pac. Used for the
4 game conversion. a 27010 EPROM.
4PACRW6C.010 : Contains 4 versions of Pacman/Ms.Pac. Used for the
4 game conversion. a 27010 EPROM. Includes the CHEAT*
versions of pacman/ms.pacman (see note at bottom).
2PACROW5.128 : Contains both Pacman and Ms.Pacman row 5 ROM files.
used for the 2 game and 4 game conversions between
Pacman and Ms.Pacman. a 27128 EPROM.
PACMSR6.512 : Contains 2 versions of Pacman/Ms.Pac. Used for the
2 game conversion. a 27512 EPROM. Does not include the cheat.
PACMSR6F.512 : Contains 2 version of Pacman/Ms.Pac fast speedup. Used
for the 2 game conversion. a 27512 EPROM. Does not include
the cheat.
MSPACR6F.512 : Contains 2 versions of Ms.Pacman (normal and fast).
Used for the 2 game conversion. a 27512 EPROM. Does not
include the cheat.
PACROW6F.512 : Contains 2 versions of Pacman (normal and fast).
include the cheat.
MSROW6.256 : Contains all the Row 6 ROM images for Ms.Pacman.
Used for the Pacman to Ms.Pacman conversion.
a 27256 EPROM. Includes the CHEAT*.
MSROW6F.256 : Contains all the Row 6 ROM images for Ms.Pacman
fast speedup version. Used for the Pacman to Ms.Pacman
conversion. a 27256 EPROM. Includes the CHEAT*.
MSROW6C.256 : Contains all the Row 6 ROM images for Ms.Pacman.
MSROW6FC.256 : Contains all the Row 6 ROM images for Ms.Pacman
MSROW5.764 : Contains the two 2532 Row 5 ROM images for Ms.Pacman.
a 2764 EPROM.
2532 EPROMs.
PAC6E.532 : Pacman 2532 EPROM image for position 6E.
PAC6F.532 : Pacman 2532 EPROM image for position 6F.
PAC6FF.532 : Pacman 2532 EPROM fast speedup image for position 6F.
PAC6FC.532 : Pacman 2532 EPROM image for position 6F with CHEAT*.
PAC6FFC.532 : Pacman 2532 EPROM fast speedup image for 6F with CHEAT*.
PAC6H.532 : Pacman 2532 EPROM image for position 6H.
PAC6J.532 : Pacman 2532 EPROM image for position 6J.
PAC5E.532 : Pacman 2532 EPROM image for position 5E.
PAC5F.532 : Pacman 2532 EPROM image for position 5F.
PACATKU6.532 : Position U6 EPROM file that goes on the ORIGINAL
Ms.Pacman daughter board. This changes the patterns
to "Ms.Pac Attack". a 2532 EPROM.
MSPACU5.716 : Position U5 EPROM file for the ORIGINAL Ms.Pacman
daughter board. a 2716 EPROM.
MSPACU6.532 : Position U6 EPROM file for the ORIGINAL Ms.Pacman
daughter board. a 2532 EPROM.
MSPACU7.532 : Position U7 EPROM file for the ORIGINAL Ms.Pacman
* The Pacman/Ms.Pacman CHEAT works like this:
- Hold down "select Player 1" button to make you invisible to the colored pacman.
You can pass right thru any attaching pacman.
- Hold down "select Player 2" button to speed up (only works in normal ROMs;
if you are using the fast ROM images, this option does not work).
So what would be the next step to get mspac running? Dave says I have 4 to many roms? Ok but I only see two based on the instructions above. The 2 extra were already solder to the board in row 5 before I touched it. I asked if I should un solder them and remove all the jumper wires?
Then Dave went on to say that I have two extras in row 6 meaning 6K & 6L okay but as a refer back to the instructions they are required?
Mabe somebody else can shed a little more light based on the instructions? Clearly it is a little confusing and not newbie proof. I belive I have followed the instructions to this point. I also have a board thats up and running garbage that did not work at all. So thats not to bad so far and I know I still have a few kinks to work out. Oh where did I go wrong???
Flame away!!!
