john2654 Well-known member Donor 3 years: 2011, 2020, 2024 VAPS Joined Mar 30, 2010 Messages 6,426 Reaction score 1,272 Location Rhinelander, Wisconsin Jul 24, 2011 #1 Installed the flyback but how do I hookup the thicker red wire and thinner gray wire? The original was a thick white wire and thin red wire. Should I match up thicknesses? Or Match red to red and white to gray? Thanks! Attachments DSC02501.jpg 99.7 KB · Views: 299
OP OP john2654 Well-known member Donor 3 years: 2011, 2020, 2024 VAPS Joined Mar 30, 2010 Messages 6,426 Reaction score 1,272 Location Rhinelander, Wisconsin Jul 24, 2011 #2 Going with this: -New flyback red to chassis white -New flyback gray to chassis red
Robomayhem New member Donor 2011 VAPS Joined Jan 10, 2009 Messages 1,894 Reaction score 88 Location Leetonia, Ohio Jul 25, 2011 #3 Whoa, quite the quandry. Good job catching that. So it worked that way?
OP OP john2654 Well-known member Donor 3 years: 2011, 2020, 2024 VAPS Joined Mar 30, 2010 Messages 6,426 Reaction score 1,272 Location Rhinelander, Wisconsin Jul 25, 2011 #4 Yes, you have to mach the thicknesses of the wires. So again: -New flyback red to chassis white (thicker wires) -New flyback gray to chassis red (thinner wires)
agetnt9 Member Joined Dec 31, 2006 Messages 202 Reaction score 0 Location Woodruff, Wisconsin Sep 28, 2011 #5 And so where do these wires go??? The thick wire go to the neck board G2 or the white part with all the pins near the center ????
OP OP john2654 Well-known member Donor 3 years: 2011, 2020, 2024 VAPS Joined Mar 30, 2010 Messages 6,426 Reaction score 1,272 Location Rhinelander, Wisconsin Sep 29, 2011 #6 Not exactly your neckboard, but it shows which one goes where. Don't pay attention to the colors, my new flyback was actually backwards in colors. The thickness of the wires is key. The thick wire from the new flyback goes to the white part that connects to the tubes pins.
