neotec nt-s500 problems
Alky
Chesterfield, Missouri
I had a bad picture on a neotec nt-S500. I did a cap kit on it except now i get white bars across the screen. After checking to see if i plugged something in wrong i finally got a picture and it still had some white lines going through it. After i turned it off and back on again i went back to the white bars again and no game picture. Does anyone know right away what this could be? I can get picks up tomorrow of the screen if needed.
Do you have a white background behind the white bars?
THe white bars can be cured by turning the screen control on the flyback down. THe intermittent display leads me to believe something isn't plugged in correctly...
yes i did have a white background behind the bars. I have 2 plugs that can be reversed, ones on the neckboard and the other is on the main board. Both are 2 pronged and 1 is 2 red wires with a black plug and 2 white wires with a white plug.
new update--- I got everything working cept there is still a fuzyness to my picture. I hooked up the game to another monitor and it is beautiful. The monitor i did the cap kit on looks exactly the same as it did before. What could be potential problems with this chassis?
