Neotec NT-500DX missing convergence rings?
sabrewulf69
Donor 3 years: 2015, 2024-2025
Has someone taken the convergence rings off of this NT-500DX? I took this monitor out of an old cabinet I had laying around and after installing it I noticed I couldn't get the image completely focused, after putting the test pattern generator on it I found the convergence was slightly off in the center and pretty bad around the edges so I went to see if the convergence rings had slipped or something only to see this...
So I'm not wrong am I, this monitor should definitely have convergence rings right? Or is that brown looking ring some kind of unadjustable factory set convergence.
The tube may have integrated rings.
The tube may have intergrated rings.
That makes sense, thanks! I had another NT-500DX that has rings but a different tube so I wasn't entirely sure.
