Neotec NT 500 DX Monitor dark
mwturnquist
Minnesota
Monitor is a little dark better when brightness is turned up all the way. With the brightness up I begin to see the zigzag line coming down from the top.
My question: Is the lack of brightness usually caused by a weak flyback or would capacitors be the most likley blame
I am going to bump this again.
I would really like some help from the community as to what the most common causes of Neotec monitors no longer being able to display a bright picture. The normal adjustments are maxed and picture is still darker than preferred.
thanks in advance
There is a color decoder / processing ic that can go bad. can cause bad contrast to a dim color like you say.. or maybe your heater voltage is shot. not the easiest monitor to work on but that what I am here for.. see my website if your interested in sending it in for repair. thanks and good luck!
