NeoTec NT-33E?
srarcade80
Orlando, Florida
Got a dedicated Gauntlet Legends showcase style cab with the giant 33" NeoTec NT-33 model. Now, this model is not telling as to which it is a C, E or V version, I was wondering if there are any ways to identify this? I've attached pics. I'm guessing its probably the E version since it was a Gauntlet cab.
I've tried sending it all 3 signals to figure it out on my own but it doesn't seem to be taking anything. It powers up, its definitely on, you can see the screen is black and adjusting brightness reveals its on but nothing as far as signal is going on the screen. This seems to be a difficult monitor to find a manual or schematic for. Any ideas?
Hv caps too.
What have you done
so far..
Are you thinking or getting a cap kit?
and dont know which kit to get?
Whats the flyback # with dual focus
Whats the crt # that will tell you the tube being used.
the one you have is dual focus not used with every chassis.
Did you get the NT-33 off the label of the chassis?
There is a Nt-33E
Theres also 38",39" Cga,Ega,Vga Nt-3500.Nt-3501.Nt-3602
A quick way to get a cap kit is remove the parts write the uf down
and there locations buy them and then call it a cap kit!
You dont even need to know which model or version
to do that and dont forget about the polys and new fly and Hot
and vertical ic and any bad connections to the remote board pots
and cold solder joints to the pins on the connectors..
If all the caps are original then they would be correct replacement
for that chassis..Good Luck!
