Neotec nt-29c
pin pal
California
I have a neotec nt-29c (manufactured in 1997) that starts out with a crisp picture when first turned on for the day but becomes progressively blurry after about 10-15 min. No other obvious problems. Will this be solved by a new cap kit? I'm a bit of a newby so apologies if there is already a thread for this.
What you should do is wait about 15-20 minutes and when the image gets as blurry as it's going to get, adjust the focus to sharpen the image. Afterwards whenever you restart the game if the image goes back to what you adjusted it to after the same 15-20 minutes you should be okay. Keep in mind these are CRT's they're supposed to warm up before use, when TV's were first introduced people would let them warm up for 30 minutes or longer I believe, you can ask Ken I'm sure he'd know.
Other than that it's probably the flyback.
Extremely common problem with the neotecs and the original flyback.
You need to replace the flyback.
I sell them on my website under the flyback/parts tab.
thanks.
Chad you are the man. The new flyback you sent me fixed the problem. Thanks again. I recommend anyone with a monitor problem to give Chad a call.
