Neotec NT-2701 Help
iN33DCaTNiP
San Diego, California
so finally got ahold of a chassis(x2) for my 27" tube and have questions...
the 2nd one has a cut flyback witch ill be replacing with new one when time permits
the 1st one on left is my main concern atm.. I eventually figured out where wires go except for the degause wire. I had to extend wires since it was cut and
that's how I received the monitor..
I figured out that the ground, 2 prong cable (in image above is silver strap) goes to neck board at location p904 (indicated by GND on map)? and I assume the degause goes
to the main chassis at p101 ? is my assumption correct ? the pdf > http://www.arcade-museum.com/manuals-monitors/Neotec 2700 Full Family version.pdf doesn't really elaborate too much
also, ill be needing a new molex connector for the degause wire ( color is red in image above )
I just want to be sure before I power the sam thing on.... and just like my 25" version, no iso is needed I bet
the 2700 has two different cap kits because there are two versions (full family and Li Chin). i have them both if you need. Iso not needed on them. i don't see the red molex connector in the picture but the deguassing one is special and GPE has them.
mine is full family ... can you link to where I can find them ?
here is closeup of that red wire from last year if it helps
the small black wire I know is grounding strap and it only fits on neck board and I assume that the red wire that is cut is degauss wire.. I extended it hopeing
to just add a new connector or is it besto replace whole thing ?
but as to other wires I have them plugged in right spot ? ground strap ?
one thing i noticed that was odd
might be nothing but in upper corner, other tab seems to be soldered down to pcb and this one isn't, will it be a issue ?
figured so.... just wanted to be sure... ill fix that tomorrow
now for the replacement degauss coil ? doesn't that plug straight in to the chassis at that location? how/where do I get right molex plug for it ?
check your center to center pin spacing in mm.
